How to Preview Documents with the Hover Panel
About the Hover Panel Component
  • The Hover Panel component lets users quickly view a document preview when they hover through their SmartHub query results.
  • If Smart Previews is installed, the document preview is shown in the panel.
  • Otherwise, the panel displays the document metadata.
Example of a Document Preview
Example of a Document Preview with Smart Previews
How to Configure Your Hover Panel
Before continuing, familiarize yourself with the information in the topic How to Use the UI Builder.
UI Builder
  • The easiest and fastest way to insert and customize the HoverPanel feature is via the SmartHub UI Builder.
  • For more information, see How to Use the UI Builder.
Procedure:
  1. SmartHub administrators can simply click the UI Editor link from the SmartHub Administration page.
  2. Click the Select a page link from the top menu.
  3. Select (double-click) an HTML page such as Results.html page.
    1. Below, the Results.html page is shown for sample purposes.
    2. BA Insight recommends you use page and folder to modify. Leave the default files as templates.
      1. For example: Customizations/Results.html. Default Results.html is under the top most SmartHub directory.
      2. See Creating Custom Pages.
  4. Select the Advanced mode from the top right of the page.
  5. Select Advanced settings edit.
  6. Scroll down to line 216 (this may vary), which contains the text SH.HoverPanel.CustomSettings
  7. Click the Default Settings. A new browser tab opens with all available SmartHub module settings.
  8. Search for the word "HoverPanel" on the page to quickly navigate to the HoverPanel default settings, shown below:
  9.     SH.HoverPanel = SH.HoverPanel || {};
        SH.HoverPanel.DefaultSettings = {
            EnableHoverPanel: false,
            EnableHoverPanelForCBS: false,
            DisplayPreview: true,
            TemplatePath: SH.RootLevelURL + "/modules/HoverPanel/templates/template.html",
            ContentTemplatePath: SH.RootLevelURL + "/modules/HoverPanel/templates/defaultContent.html",
            CorrectionLeft: 0,
            CorrectionTop: 0,
            HoverSelector: ".sh-result-item", // For TabularView use ".k-master-row"; For CoveoResults use ".CoveoResult"; For ContentContainers use ".sh-result-item"
            CloseHoverPanelWhenHoverOver: ".coveo-header-zone,.header-info,.footer-zone,.sidebar",
            ViewButtonLabel: "View".toLocaleString(),
            ViewButtonTooltip: "Open in viewer".toLocaleString(),
            AddPageButtonLabel: "Add page to workspace".toLocaleString(),
            AddPageButtonTooltip: "Add this page to workspace".toLocaleString(),
            AddDocumentButtonLabel: "Add document to workspace".toLocaleString(),
            AddDocumentButtonTooltip: "Add full document to workspace".toLocaleString(),
            DelayTime: 300
  10. Copy the HoverPanel settings section from SH.HoverPanel.DefaultSettings.
  11. Go back to your Advanced settings edit tab.
  12. Paste the copied settings inside section SH.HoverPanel.CustomSettings.
  13. EnableHoverPanel value is set to "false" by default.
  14. Modify settings as desired. See the "Hover Panel Settings" table below.
  15. Click Save changes.
  16. Click the link Preview <html> file.html at the top of the code editor.
  17. Review your HTML page in the new tab that opens.
  18. Make any necessary changes back in the code editor. Repeat steps 14-18 as necessary.
  19. Click Save changes.
Settings Example
SH.HoverPanel.CustomSettings = {
    EnableHoverPanel: "true"};
SH.HoverPanel.PathsToExclude =[];
Setting Name Default Value Description
EnableHoverPanel false
  • true - Hover Panel is enabled.
  • false - Hover Panel is disabled.
EnableHoverPanelForCBS  false
  • true - Hover Panel for Content By Search components is enabled.
  • false - Hover Panel for Content By Search components is disabled.
DisplayPreview true
  • true - if available, preview is displayed.
  • false - document metadata will always be displayed, even when preview exists.
TemplatePath /modules/HoverPanel/templates/template.html
  • The path for the Hover Panel template.
  • You can customize the template and provide the path to the custom template here.
ContentTemplatePath /modules/HoverPanel/templates/defaultContent.html
  • The path for the content template for document metadata.
  • Customize this if you want to show different metadata in the panel.
CorrectionLeft 0
  • The number of pixels used to shift the hover panel to the left.
  • This can be a negative value.
CorrectionTop 0
  • the number of pixels used to shift the hover panel to the top.
  • This can be a negative value .
HoverSelector .CoveoResult
  • Hover panel will be displayed when you hover over elements with this selector.
  • For TabularView, use ".k-master-row".
CloseHoverPanelWhenHoverOver .coveo-header-zone,.header-info,.footer-zone,.sidebar A list of class selectors that, when hovering over the elements with one of the specified class, the hover panel will automatically close
ViewButtonLabel View The label of the "View" button.
ViewButtonTooltip Open in viewer
  • The tooltip of the "View" button.
  • Provides details about the performed action when clicking the button
AddPageButtonLabel Add page to workspace The label of the "Add page to workspace" button .
AddPageButtonTooltip Add this page to workspace
  • The tooltip of the "Add page to workspace" button.
  • Provides details about the performed action when clicking the button.
AddDocumentButtonLabel Add document to workspace The label of the "Add document to workspace" button.
AddDocumentButtonTooltip Add full document to workspace
  • The tooltip of the "Add document to workspace" button.
DelayTime 300 Number of milliseconds that you have to hover over an item in order for hover panel to be displayed.
How to Show Different Metadata in Your Hover Panel
The default template can be found in the directory \modules\HoverPanel\templates\defaultContent.html.
This file must be used only as an example and it should not be modified because it will be overwritten at upgrade time.
  1. In order to customize the metadata shown, create a new HTML file in your customizations folder, and copy the content of defaultContent.html in it.
  2. Modify the new template adding the following snippet for every metadata property that you want to show:
    <div class="hp-content-property">
        <div class="hp-content-subtitle">
            Custom metadata title
        </div>
        <div class="hp-content-property-value">
            <%= resultItem.CustomMetadata %>
        </div>
    </div>
    Example of Custom Template
    <div id="<%= 'hp-metadata-container_' + elementId %>">
                Contributors include
            </div>
                <%= resultItem.DisplayAuthor %>
            </div>
        </div>
                Last modified
            </div>
                <%= new Date(resultItem.LastModifiedTime).toLocaleDateString() %>
            </div>
        </div>
            </div>
            </div>
        </div>
    </div>
  3. Change the ContentTemplatePath setting to the path of the new custom template.
        EnableHoverPanel: "true",
        ContentTemplatePath: "/modules/customizations/HoverPanel/templates/customContent.html"};
How to Disable the Hover Panel Component
To disable your Hover Panel, use the following instructions:
  1. Follow steps 1-6 in How to Configure Your Hover Panel.
  2. Change the EnableHoverPanel value to "false".
        EnableHoverPanel: "false"};
  3. Click Save changes.
